Huawei p10 Camera blurry
  • Start date Start date
Can any of you guys affected perhaps post screenshots of the problem so we can see what it looks like?
I have the same problem. I read in another site that it might be caused by an impact. I have this phone since 2 months ago, and the only time i dropped it was from my bed. Anyway, it seems that the problem is a hardware problem. I hope it is not.....
Same problem here. Camera won't focus at all. Everything blurs as pic attached.
I was reading the different posts a few days ago, and i was (and still am) convinced that the problem is a hardware problem. The right part of my screen was out of focus (color sensor). I bought the replacement part, and i'm waiting for it to arrive (40 days to Argentina), so i decided to try the different solutions while the replacement arrives. If i hit the phone with my hand, or against the table, nothing happens. (always checking that the monochrome sensor is OK). What worked for me, was to stand the phone on a table, and let it fall screen down (check the table is clean of any particule that could damage the screen). I did this a couple of times....and now is far better. Not perfect as the monochrome, but i can take a picture now. It seems that the zooming parts are somehow stucked. I'm still replacing this component...but it might help you.
I have the same issue... Lebanon... Rear camera is giving blurring images all way long... Have tried to stand it on table and let him fall down and same results... You might think that that an OS upgarde will solve this matter?
My friend you are a small God!!! I try the trick with the table.... After 4 times camera work perfectly. Is just the first day so I will see soon if this gonna last for ever or not. Thanks anyway!!!
Wow, glad that got it working! Guess the mechanism was just stuck.
could you explain in detail how to do it
as i couldn't understand it
It's a mechanical defect. Dropping the phone on the table might rectify it, but if it doesn't then a higher drop may work. But be careful, as you can also cause further damage to the phone if you try it.
I don't know if this will work for everybody.
The main camera of my new Huawei P10 Lite has been blurry for days.
After the following procedure it started to work just great again:
1. I turned on the Perfect Selfie feature
2. Then I took a photo with the front camera (a selfie)
3. Then, when i switch to the main camera it was working again!!!
This just happened and I don't know how long it will last. Don't know either if this will work again or if it'll work for everybody with the same problem, so I just drop this tip and hope it'll help others!!
Just put your phone standing on a table, and let it fall screen down. It seems that an impact perpendicular to the screen moves the components inside the zooming mechanism in a propper way (that's why hitting it with your hand doesn't work). But it work just for a couple of photos....after that is blurry again.
kenster23
