I have a Thrive right now.
Let me ask, I know I've read it and cannot find this answer difinitively. What is the largest size SD card the Thrive can accomodate? Thanks!
I currently have the Samsung 10.1 Tab. It is awesome but the lack of accessories (yes I know they are online) in the stores and the fact that it cannot be expanded like the Thrive can, I am considering trading it in since I am within my 14 days with BB. My local BB has them in stock and one of the workers took one out for me to play with. It is sweet! I will say the screen seems to be better on my Sammy (color and brightness). So, I guess what I am getting at is this. Would you trade in a Galaxy 10.1 for the Thrive? Is it that good?
Thanks!
I guess these tablets doesn't come under 14 days limitation, instead 30 days and 45 days for Silver premier members. Currently I'm playing with both of them. IMO, currently Samsung Tab 10.1 has upper hands on the display and speakers. Other than that, rest of the specs on current Honeycomb tablets are more or less same. May be you can check with your local BB about the 30 days limitation, and if it says it is, then get the Thrive and compare it side by side hands on. Though, it'll be hard to keep your eyes off from Samsung Tab 10.1 ;)
Isn't the largest SD card 32GB? Or has it grown since I shopped them? The Thrive will take a 32GB card.
Are we able to remove manufacturer's apps like the Kaspersky app like we can on the HTC EVO 3D (and I believe the Thunderbolt too). Once that trial is over, the app would be useless.. =/
I tried to remove BOOK PLACE app on Home page by going to Settings>Applications
then Clicking on Force Stop and the Clear Data
Did not work.
Did not work.
But BOOK PLACE is an app . . .Clear Data wouldn't remove the app itself---only the data (info) you may have added to the app . . . Right?
And the Force Stop would only stop BOOK PLACE from running . . .
Confirmation please:
Movie apps, either Netflix(Thru the app market) or BlockBuster(preloaded)????
I'd be interested in how you guys think the display compared w/ an iPad2 or Tab as well...the Transformer has a lot of glare unfortunately :-P
If it compares favorably w/ an Apple CinemaHD display, it certainly can't be worse than a Transformer's IPS display...
And does it have haptic vibration feedback? There's probably space in it for that...the Transformer is missing it.
I just got mine at the local BB. I was surprised to see a display model on the floor. I thought I was going to have to beg them to buy it today. :) Yes, it does have haptic feedback.
lol...I bought one today and it's the same thing as the Galaxy 10.1 with the addition of an SD slot...too many bugs in Honeycomb...will be going back tomorrow.
I was at BB this afternoon and compared the Tab to the Thrive and I have no idea what you mean when you say the Thrive is the same thing as a Galaxy Tab.
The Thrive is thicker, weighs a bit more, has a different backing, has a full-sized USB slot, anHDMI port, a user-replaceable battery, a 5 MP camera on the back, and an SD card slot.
Somehow, I am missing how the two are "the same thing" except for the SD card slot.
LOL another one bites the dust
sent to you in three dimensions
He means honeycomb being buggy
I just got my thrive and Im waiting for it to arrive to my home. Any good suggestions in apps to use (apart from the usual ones like twitter and facebook) to juice up the thrive?
also is the Pen a good buy? every review says they're "average".
I'm kinda worried of staining the thrive with my fingers (I know how nasty can it get.. as I 've left a lot of fingerprints in my Samsung Epic.
Techman
