I rooted with unrevoked.. HAPPY!!
Currently running unrooted Froyo,
My primary question is will rooting my phone using the one step method fix the horrible audio quality while streaming Pandora and resolve the problem with playing audio and using Google Nav simultaneously? Or will I have to try and go back to Eclair (2.1).
is there a way to fix the FPS once you are rooted with unrevoked .. do i have to install a rom and if so will cm6 work with unrevoked????
okay I followed all the steps and after the drivers were installed it said done, but now what? it doesn't look like it worked I don't see anything different on the phone did I do something wrong?
Some ROM's fix this.
Some ROM's fix this. CM6 requires NAND to be unlocked. If unrevoked does this then yes it'll work.
Im also interested on how to adjust the fps rate once rooted via unrevoked
Some ROM's/kernels fix this. It's not adjustable.
All of these have already been answered. Please go to the ROMS and Hacks section and search. Do a little research. I was a n00b once and reading ahead answered the majority of my questions.
You should have an app called super user (or download it from the market and see if it works).
the older Unrevoked was not considered to be a full root...is this new version a full root?
Just so im clear... if I root with unrevoked 3.21 I can still return to stock (unroot) if need be?
^^ want to know how to do this? do i just hold power and volume down and go to recovery mode.. or is there more to it?
slackingfred
