i try to replace my 32GB SD card with another 32GB SD card and it did not work
  • Start date Start date
A
Android Central Question
so as i inserted the new 32GB SD card it the mount SD card did not appear it was as if there were no card in the slot i took it out and put it back in but the same thing happen then i powered it off and restarted it etc but the end result nothing i did work
if your old SD card is properly working on your smartphone then this means that, there is no any issue with your smartphone. Please try your 32GB SD card in any other 32GB supported phone and it's working on that mobile or not. May be your SD card is crashed..
Does the new card work in other devices? It's possible it's just a bum card, this is what a warranty is for...
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
zolepso1
