Ics phone signal really bad
Try going into recovery and wiping cache. I have zero problems with my signal
Sent from my RAZR MAXXIMUS ;)
After resetting to factory Maxx is acting a WHOLE lot better. I am at 60% after nearly 7 hours of moderate use.
And the best part is the signal is pretty much normal again. Today I went in the same rural area that I did last week with ics installed on top of gb.. Before restoring to factory and the signal was very bad. Bad enough to start this thread.
After restoring to factory and having a clean ICS install, my signal in that same area was near perfect. Just like it used to be on GB.
So, if you're having battery or signal problems and you installed ics on top of gb.... Do yourself a favor and restore to factory settings.
Sent from my DROID RAZR using Tapatalk 2
Humanlymortal
