[ICS] Screenshot for Razr Maxx
Another one from me.
Clock widget is DigiClock 4.0 beta by David Goemans. It has more fonts than the current version in Google Play, and more customization options. It's only available from his website DigiClock Beta | DavidGoemans.com
Live wallpaper is Mystical Halo. It is awesome, IMHO. Think Star Wars crossed with Tron.
Very sharp! What's the small shield icon next to Battery Circle in the notification area?
Nova launcher with Beautiful Widget weather and clock... simple and clean home screen.
Reactions: bradenfontaine
Stock ICS launcher and wallpaper, Beautiful Widgets with Roboto Clear theme. I'm working on cleaning it up a bit, but I use everything on that screen frequently enough to keep it as-is.
Sent from my DROID RAZR using Tapatalk 2
My Maxx's latest look. The wallpaper is from zedge.net. The screen has:
- Fancy Widgets Clock\Weather
- Smooth Calendar
- Toggle Widgets
I piled six apps into the Main Apps folder on the bottom task bar.
Thank you!!!:D
Sent from my DROID RAZR using Android Central Forums
Not a problem... today I saw this new version of the same one.... Motorola Atrix Hd Widgets On Razr!
****EDIT: But it does require you load a newer (Larger) launcher, because it will not run on your stock launcher or any other launcher (I tried to use Nova). Nice idea if you want to play with your device, or loaded it on a test ROM.
Here's my latest screen.
Using Elixir 2 Widgets for the toggles. One More Clock and Battery Circle (I think) is the battery in the Notification Bar. Live Wallpaper is Digital Embers.
maryhurst515
