[ICS] Screenshot for Razr Maxx
which "glass" dock is that?
It's just one of fifteen different dock backgrounds in Go Launcher. They don't have names but it's why I like GL so much, plus you can easily create your own. Notice my icons are customized too. The phone and address book are downloaded from the web and applied. Want it to be unique right? :cool:
Reactions: bradenfontaine
fatboy97, what clock and weather app are you using?
It's part of Beautiful Widget's... they have so many options to choose from... so, this is their Small widget which I think fits really nicely without being too big... the clock is their NakedDroid3D clock and their SimpleWeather weather theme... you get to mix and match whatever you want.
Bdiddy - can you tell me how to adjust the power widget from painless death? When I try to add to screen it just gives me the square with settings circle..... Help??!!
Sent from my DROID RAZR using Android Central Forums
To add it to your homescreen, first go to Widgets, select Power Controls, and drag to your homescreen.
What comes up next is the customization menu. The preview of your toggle bar is at the top. Tap any of the icons--you can then discard it from the bar (trashcan) or move it (drag the slider bar that appears just under the toggle bar). To add another toggle to the bar, tap "Add Toggle" at the bottom of the screen.
You can also adjust the transparency of the bar (all the way to the right, and the bar has a solid black background; all the way the left, and it's completely transparent). You can adjust the button colors lower down.
When you're done, hit Done, and voila, there's your toggle bar.
To edit an existing toggle bar on your screen, go to Apps (not Widgets), and select Power Controls. The house symbol at the upper left tells you how many toggle bars you have created. Tapping the house allows you to edit any one of them--you'll go to the edit screen that I described above.
The box at the upper right allows you to put your toggle bar in the Notification pulldown. Hit the check mark to place it in Notifications, and the sliders icon to edit how it looks. The pin icon is some Accessibility function, allowing you to make sure it's always on top.
Under Global settings, you can adjust the 3 brightness settings of the brightness toggle on this screen. The 3 numbers indicate the level of brightness for low, medium, and high. (There's also an Automatic brightness selection when you're toggling through.) Screen Timeout is another toggle you can add to your bar, and under Global Settings, you can adjust the time in seconds for each setting. Icon for GPRS Toggle just changes what your mobile data toggle looks like--if you don't have 4G, you can make it say 3G instead (it's still the same function, though, in that it just toggles your mobile data).
Not the most elegant menu system, I agree, but hey, it's free, and works pretty well! Hope this helps.
Decided to go with a simple and stealth home screen. I'll call it "Black Ops.":D
Taeisme, love it, where did you get wallpaper
Sent from my DROID RAZR MAXX using Android Central Forums
Another one from me.
Clock widget is DigiClock 4.0 beta by David Goemans. It has more fonts than the current version in Google Play, and more customization options. It's only available from his website DigiClock Beta | DavidGoemans.com
Live wallpaper is Mystical Halo. It is awesome, IMHO. Think Star Wars crossed with Tron.
Page 38 of the updated-for-ics Razr Maxx User's Guide indicates how to take a screen shot. When I press and hold the down-volume key and the power key for 3 seconds, nothing happens. There is no camera shutter click and there is no result in My Gallery > Screenshots. In fact, there is no Screenshots folder.
It seems everybody in this thread but me can take screenshots. I would be grateful if somebody would hazard a guess about what I might be doing wrong.
Many thanks!
I find it a little tricky. It seems to work best if you press both of those button at exactly the same time, rather than pressing one down, then following with the other.
yanis
