NotJustAPhone
- Jan 29, 2011
- 5,371
- 734
- 0
You may need to flash a new radio depending on how long you've had your phone and what version of the stock software you were running when you rooted. Check on your phone and let us know.
How long have you had your TBolt? It's possible that your phone has an older radio version that does not work with your ROM. Check Settings/About Phone and see what it says about baseband version.
I flash them just like I did the bamf stuff?
ok I went into recovery and then tried to install zip from sd. Picked the still ziped imgo5 file. its started and then said installation aborted.
ok so now I need to go back into recovery and make a backup right?
