shortwave8669
- Jun 23, 2014
- 268
- 0
- 0
Re: [Instruction] How to Keep Unlimited Data on Verizon
Hi Notwist,
I am NO EXPERT on handling transfers from one line to another and UDP.
I don't want to give you any bad advice and jeopardize your UDP.
I'll see if I can read thru other's advice ( e.g. dusoccer10) and try to help.
I'd suggest not doing anything with the new device until we know for sure the process.
Best regards
Hi Guys,
L1 - Unlimited Data, Upgrade Available, Note 2
L2 - Tiered Data, Upgrade Available, S3
I ordered a Note 5 online from Verizon using L2 Upgrade, it just arrived. I want to use it on L1 and Note 2 on L2
Do I just take out the Note 5 sim out (without turning Note 5 on, out of the box) and put L1 sim to the device ( after cutting it to nano size) and take out S3 sim and put it on Note 2 on L2?
OR
Do I activate the Note 5 with the sim it came with? Then after an hour put the L1 sim into it and put the new L2 sim to Note 2?
OR
Can I just activate the new phone with the new sim on L1 online? and just move L2 sim to Note2? So I dont have to cut nano sim or use adapters?
Please let me know.
Thanks!!!
Hi Notwist,
Best regards
