Verizon Galaxy S8 Is anybody able to get "OK Google" to unlock their S8 or S8+?
Re: Is anybody able to get "OK Google" to unlock their S8 or S8+?
no, it wont. the wording is different. on my lg v20, its says "even when the device is off"
Nah not working... I waved all over the place lol
OK then. It may be a setting.
I will look...
Mav. :cool:
P.S. You have "Smart Lock" on?
The AT&T version does work (unlock), when on a charger without pressing anything, of course I have set up as a trusted voice.
navigate to Settings -> Accessibility -> Dexterity and interaction -> Easy screen turn on. Make sure to toggle it on.
See if that works.
Ok Google will work from the lock screen. If no security is set up than it will work ONLY if plugged in. If security is set up, password, figure print, etc, than you also have to setup your voice as a trusted device. And it still must be plugged in to a power source.
I do remember there is an app that allows you to use S Voice to activate Google Search. S Voice can work from the lock screen without being plugged in. It was clumsy but it worked.
OlSkool
