is it possible to overclock nook color running cm7
lions80
70
I just came from running rooted 2.1 to cm7. I had 2.1 overclocked to 1100. I've checked plenty of forums without an answer. Can NC be overclocked when using cm7. If so, how do I do IT?
are you sure you checked plenty of forums?? this forum here has a thread on cm7 that has links for how to overclock and xda-developers has a bunch as well. check there for your answer.
texanmason
