Is there a way to block all calls without turning on Airplane Mode?
jaymzb0nd
160
18
Hi. Sometimes I don't want to receive calls but still want to use my phone to listen to music in the car (with bluetooth) or use data when at home. Is there another way besides Airplane Mode to be able to not receive calls (send them automatically to voicemail)?
I'm sure that you can set up the appropriate tasks in Tasker to do that.
AT&T's Drive mode might be a solution.
Open your phone dialer, go to settings, go to More Settings, select Call Forwarding and make your change.
No setting called "Call Forwarding."
What phone and os are you using? You can also turn off data and wifi.
Screenshot of More Settings
RangelS25
