Is there a way to reboot or shutdow the devie without hold down the power button?
I apologize for my post. I didn't realize that I did that (posting in the wrong forum). How do I get it moved or deleted?
I requested for a move but it never got moved. Not a big deal.
Sent from my Motorola Droid Maxx using Tapatalk 4
I've had this same problem for the past week and there is a really simple fix. I wasted lots of time rooting my phone and trying different apps so I'm trying to post this everywhere I can find. Obviously without a power button you have two problems: 1) you can't turn the screen on and off 2) you can't turn the phone on if the battery completely dies or is removed.
Solution to not being able to turn screen on and off
-Download one of the many apps that uses the accelerometer and/or proximity sensor to control the screen (such as 'Awesome On Off')
Solution to not being able to power on the phone
-Use "recovery mode" to turn the phone on and then click to restart the phone. Google search for how to enter recovery mode for your specific device, but for the Galaxy S2 Skyrocket you turn the phone off, disconnect the charging cable, and while it's off you press and hold both volume buttons at once. While holding these buttons you connect the usb charging cable and a message pops up telling you to press "volume up" to enter recovery mode or press "volume down" to exit recovery mode and restart the phone. Do this second option. Your phone will reboot and you'll be back to your home screen.
Hope this helps someone!
RangelS25
