- Feb 6, 2017
- 98,886
- 15,532
- 113
That might be the reason because of region, sorry you won't be able to flash the international version to USI'm in San Diego, CA, USA.
That's the problem.Is there another version that I can flash for my region?
Unfortunately US is different from international version they cannot be flash with each otherIs there another version that I can flash for my region?
Yes thanksThat's the problem.
If I understand what @mustang7757 is saying, that phone will only take the international firmware because it's the international version. No US version will load. And since your region is the US, you're stuck.
I'd suggest returning it for a true US variant. Model number SM-S928U or SM-S928U1.
It won't be a brick but some things won't work, try using a VPN to see if it will allow you to download the appWow, I hate to think I bought a brick.
Are you able to return the phone for a refund?Wow, I hate to think I bought a brick.
No. Craigslist special.Are you able to return the phone for a refund?
I use Express VPN at home. Can I use this phone?It won't be a brick but some things won't work, try using a VPN to see if it will allow you to download the app
If it has a mobile versionI use Express VPN at home. Can I use this phone?
What is the model and the firmware version of the phone?I'm in San Diego, CA, USA.
I deleted your recent screenshot, block the IMEI alsoI use Express VPN at home. Can I use this phone?
Yup. That's a grey market device. You are not screwed. The device will work. You should be able to change the CSC. Because it is not a US model, you can root (although I don't recommend it). You don't need to root to change the CSC.
Which carrier do you plan to use this on?Using. https://samfw.com/firmware/SM-S928B
I see lots of firmware. Which one would be recommended to work in the US without restrictions? I don't mind not being able to record a call, I just want it to work like a normal US phone..
I doubt you will find firmware for your phone that has AT&T's CSC (ATT/XAA or ATT/ATT). That is what is preventing you from loading those specific apps. I don't think you can flash the S928U or S928U1 firmware onto your phone.Using. https://samfw.com/firmware/SM-S928B
