I've got the Honor 5X - you have questions - fire away!
Thanks a lot. I did set my default storage to SD card... I am going to try moving app to the SD card then. Thanks!
cool, however please note, not all apps are movable to SD. most of them are but not all still all media and files can moved.
I don't have the phone yet; I know Tinder doesn't work on my Windows phone, so I wanted to know if there exists a similar limitation on this phone before I buy it (Tinder is pretty popular, though; I really don't know what a 'normal app' is, but I would think it qualifies).
yes it works on honor. it doesnt on Windows as windows and iOS have limitation.
For a 720p screen it's not bad at all. My other Android phone atm is the Oneplus Two - and honestly I don't notice much difference side by side.
i'm looking at getting either of these phones can't decide between the 2. can get the honor 5x £60 cheaper than the op2
which should I go for?
its the 2gb ram version of 5x and the 4gb ram version of op2 that are for sale
Check this out before you make your mind. Go for Honro 5X you will get the best in the segment.
https://club.hihonor.com/in/honor5x...ng-look-feel-and-the-real-smartphone-era.3127
https://club.hihonor.com/in/honor5x...-a-featured-packed-phone-honor-5x-it-is-.3251
On Amazon's prime day I scored a Huawei honor 5X for only $120. I heard that it should receive an OTA upgrade from lollipop to marshmallow. Anyone know when that update should be pushed?
You can manually upgrade it now.
Hi
Bought me a Honor 5x and can't find the dual window option, it's not under settings menu.
Can anyone tell me what that is?
Thx.
I have a question for you about honor 5x how do you delete message log? Dumb question cannot figure it out thanks
Tfunz
