I've got the Honor 5X - you have questions - fire away!
Would this device purchased in US work in Europe? What frequencies does it support? Does it have any SIM-card region lock?
What bands does it need in Europe?
This is the US model:
Honor 5X specs | Android Central
GSM (GSM 850): 824–849 MHz (UL), 869–894 MHz (DL)
EGSM (GSM 900): 880–915 MHz (UL), 925–960 MHz (DL)
DCS (GSM 1800): 1710–1785 MHz (UL), 1805–1880 MHz (DL)
PCS (GSM 1900): 1850–1910 MHz (UL), 1930–1990 MHz (DL)
WCDMA Band 1 (WCDMA 2100): 1920–1980 MHz (UL), 2110–2170 MHz (DL)
WCDMA Band 2 (WCDMA 1900): 1850–1910 MHz (UL), 1930–1990 MHz (DL)
WCDMA Band 4 (WCDMA 1700): 1710–1755 MHz (UL), 2110–2155 MHz (DL)
WCDMA Band 5 (WCDMA 850): 824–849 MHz (UL), 869–894 MHz (DL)
LTE FDD Band 2: 1850–1910 MHz (UL), 1930–1990 MHz (DL)
LTE FDD Band 4: 1710–1755 MHz (UL), 2110–2155 MHz (DL)
LTE FDD Band 5: 824–849 MHz (UL), 869–894 MHz (DL)
LTE FDD Band 12: 699–716 MHz (UL),729–746 MHz (DL)
LTE FDD Band 17: 704–716 MHz (UL), 734–746 MHz (DL)
It goes on sale in Europe on Feb 4: https://www.vmall.eu/uk/honor-5x-silver-287386/
Can someone recommend a higher quality brick that would provide more juice for faster charging this 5x?
Thanks for the reply Ry. I purchased the device on US amazon and intend to use it in Europe on:
900/1800 MHz GSM (GPRS, EDGE)
2100 MHz UMTS, HSDPA
1800 MHz LTE
Based on your feedback I assume I should be OK? Hoping the device does not include some kind of Samsung region lock?
1800 MHz LTE
I think 1800 is Band 3 and it's not listed for the US Honor 5X.
Did you guys try the OTG compatibility with 3rd party file managers like ES File Explorer?
I really really hope it works, coz I use OTG pendrives a lot with my phones.....
I don't have Android auto, so I can't test that. Bluetooth streaming works great for me. After the initial pairing, it connects automatically and quickly without any intervention from me.
but does this phone support 2A charging. They provided 1A charger with this but as Amazon site have this in detail-
More life
Longer usage time with a 3000 mAh battery and SmartPower 3.0
2A charger for significantly shorter charging times. Integrated SmartPower 3.0 technology with eight-point power saving plan to reduce power consumption by 30 percent. Battery life that lasts 1.46 days with moderate use and over a day with heavy use. (Data based on Huawei laboratory tests, actual times may vary).
can it support 2A without damaging anything.
My phone is making a bit of a rattling sound when I shake it or put it down on a hard surface or tap on the back. I took out the simcards and that did not stop the sound so it is not the cards making noise.
It almost sounds like it is the camera lens that has come loose? I am pretty sure it didn't make this noise yesterday.
Anyone else notice any rattling?
I bought one for my dad. I can ask him and report back.
My wife just got the Honor 5x and has lost both the icons for phone and messages. With no app drawer, I'm having a hard time finding them to recopy to her tray. At least contacts has both phone (left swipe) and messages (right swipe), but how can I recopy the icons? Thanks.
Reset the app preferences in the setting...app management and it should be fine or else take a backup with hi suites and do a factory reset and then restore the backup.
Get it replaced.no such issues
qunasfoma
