iVoler Tempered Glass Screen Protector
Define "halo" for me. Like it appears to bubble up on the ends? Or a corner is coming up? Or it just looks like the very very tippy edge all the way around isn't sticking?
I know, I know, dumb question, but see my earlier post in this thread; I'm kinda-sorta new to the tempered glass stuff. :)
The edges are almost white rather than clear. If you put pressure on the edge it'll change for a second and then lift again normally.
Mine after a month of good use popped up on the lower right corner, a fairly large spot. No idea what happened.
I don't have this. Luck I guess. I am extremely please with mine.
This would help validate my point that iVoler has quality control issues. The amount of lifting was varied significantly in all 3 I installed with the same alignment.
Shame, really.
Jayarealways
