Jelly Bean 4.2 Camera
I'm glad they sourced it correctly.
/sarcasm
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
yeah, pretty lazy on their part. I left a comment (and so have a few others, actually) mentioning this as the OG thread
No matter what i do move the gallery.apk or flash it still doesn't work, just "Unfortunately Gallery has stopped". I'm on stock 4.1.1 Galaxy Nexus unlock and rooted.
I even dirty flash countless times to no avail
Anyone having the same issue, anyway to revert back? since I have overwrite the original apk.
Sigh... Rather have a gallery then totally nothing please help
THANKS!
Can someone patch apk to add HTC One X to a list of supported devices? Camera shows model "HTC One X (HTC)". HOX has gyro.
Hey guys, I've been reading through this post, and I'm a little confused about how to install the new gallery and camera app for my galaxy nexus. Can someone post a quick step by step instruction on how to do it. Thanks!
K so heres what i did to make it work so that i didnt get the gallery FC error. BTW im on AOKP JB Milestone 1 w/ Franco kernal. Flash the 4.2Camera_t01.zip file in recovery. then boot back up. Once your OS has loaded, you will most likely get a gallery FC error. I used Root Explorer and went to System-App and you will see a Gallery2.apk file. I renamed it to Gallery2.bak. Once thats done, REBOOT your phone. Once it loaded back up, i never got the FC again. If you had app icons for camera or gallery on your homescreen, they will be gone. Just go back to your drawer and re add the app icon shortcut to your homescreen. Hope this helps out
Anyone able to get this working successfully on a Galaxy S3 yet?
Me but photo with flash fc's everything else is fine
I9300 running omega v31
Oh and the photosphere viewing button doesn't work reading back a couple pages, apparently it needs an app..
It works but doesn't work on my S3. It lets me use the Sphere, video. But sometimes the "normal" camera doesn't work and is FCed and I have to reboot.
It always lets me take the first photo, but then when I take another, it FCs
Thanks for the share.
I followed your OP and dropped .apk and other library files where they belonged and it worked. Except for when you take a sphere photo and then click on the round thing to be able to move/pan around the photo that doesn't work.
SGS III (i747) running a port of JellyBean Leak (L710VPBLJ7 Sprint Base) ROM called JellyBean747 Milestone 7 Graystone Edition
The "Streetview" interface isn't working but one thing you can do is get the photo on a PC(email it, usb it over...whatever) but you need it in it's full uncompressed, unchanged glory. Then upload it to Google+. Then click on the photo and it lets you look around it
Photoshere and basic camera working fine on my Toroplus.
Proof on my g+ page :) and here
Edit: can see full photo if you open on my g+ page gplus.to/ajohnson
Getting not supported for photosphere on sgs2 i777. Everything else looks golden. Thanks for all your hard work.
Ashok Dharshan
