Jellybean Keyboard Help?!
amy1503
3
Hi all
Yesterday my S3 updated to android version 4.3
This update has changed a lot on my phone including my keyboard to a QWERTY one
I really like the update apart from the change of keyboard as i really can't get on with it and when I have looked for how to change it back to the 3x4 keyboard I can't seem to find it anywhere.
Anyone know how I do this?
Thanks
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Hi all
Thanks
Try going into Settings>Language and input. The Samsung keyboard should be there with a settings icon to the far right of the entry. Tap that, and you should get keyboard setups.
If that doesn't work, you may need to get a different keyboard form Play.
ukfred
