Jellybean thoughts
Not everyone could go out and buy a phone like nothing.
Plus its kind of easier to install a rom than going through the whole activation process.
~Vortex Corporation~
Its a cheap tablet. Its the price of the V when it first came out. 200. I agree with Anthony, if you really want JB, buy the Nexus 7. :p
What do you mean? You don't activate tablets unless they are on the network.
What i meant was that the same holds true that not everyone can go out and buy a $200 tablet either.
I don't think that if you want JB you should just go buy a nexus 7 (although that's a good idea).
I can't believe this is actually happening :D. I just want to say thank you, thank you, thank you, thank you.
Reactions: sellers86
Cyanogenmod had an article saying it was a piece of cake. Not a problem at all.
Any device running CM9 should run CM10, they said.
You guys working on it too? Cm10 isn't build able yet. But trust me, I'm syncing every 10 seconds
Sent from my Amazon Kindle Fire using Tapatalk 2
I am to. im putting cna and my secret project on hold until I can at least make it partway into the build. Are you going to work on it for the OV?
Its actually a bad time four me, I just started hacking on the ics kernel. I thought I'd have at least one or two more weeks...
If you need a break, I'm sure the people over at your thread wouldn't mind too much :D
The Google Play Music app that ships with Jellybean is great. Much better widget and built-in EQ. Runs on ICS too, the APK is floating around the internet somewhere, just do a Google search.
+1, That's all I've been using lately. It has some lag on CM7 with using volume rockers to switch songs whem screen is off, but other than that, its flawless.
Yea, I'm liking it so much that i'm actually thinking of getting the Nexus for the full experience. I can not wait until we get Jelly Bean for the OV and my Droid.
Sent from my shole using Tapatalk 2
There are now two jb aosp builds out for the kindle fire now. I will probably wait for cm10 before it try it though. People seem to like it though.
sent from my Nokia 5110
Techman
