Just in general, is anyone having any issues with their sgs3?
Loads of problems, not happy at all:
  1. Sometimes won't wake up from screen off standby. Have to remove battery
  2. Sometimes notification bar can't be dragged down. Have to reboot
  3. Randomly reboots
  4. Battery life is awful when low H signal, constantly jumping between H & G. Needs a de-bouncing algorithm
I've already done factory resets, and it solves the problem for a few weeks, but not happy at all.
Factory reset shouldn't be "common practice" to solve bad programming.
I have rooted gs3 and flashed darther stalker now my mic barely if not completely doesn't work. I flashed it back to stock but still problematic.Anything, please? HELP!!
I posted a thread about an error pop up message I kept getting like every 30 seconds or go while using the phone. I had to do a Factory reset and it fixed it. Also I do have the issue with not getting signal where with my previous phone I used to. At my job(at a hospital), with mytouch phone, used to get okay signal, now I have to stay on wifi if I want to get on internet. I also have an issue now with my contacts, I don't want my FB contacts to sync, already went to account syncs and removed it and still does not work.
Uninstall FB and the FB numbers would go away.... after you can re install FB, and make sure you don't allow sync again when opening FB.
RangelS25
