If your battery is still at or above 50% after 24 hours then you are barely using it. Battery life is all in the usage. The best thing to do if you use your phone heavy and want to conserve battery is to use little to no screen brightness.
nice, is that on the whole time or do you shut it off at night? Mine is on the whole time, not sure if the timer resets if you shut off as I have not tried yet but I do know it resets if you pull the battery
how do you guys do this? I get about 10 hrs max out of a battery.
Yep, I use the battery saver mode as well...though I have mine customized from 11p - 5am. My battery easily goes the night without dropping 10% using this setting.It was on the whole time... I used it sparingly but no games. I also had it in the battery saving mode from 10p-5a. I have since went to Froyo and it seems to be good as well. So needless to say I am happy with the battery life on the X.
Also, by turning off 3G to avoid connecting all day if there isn't a strong signal saves a ton of battery. I also use Battery Saver mode all day long.
My battery life is terrible..... usually take it off charge around 7am and by 5pm i need to recharge or im screwed
