Kies Air very flaky - Help!
vidroid
Active member
Jun 1, 2012
31
New SII owner here. I have managed to connect to my phone from my computer (Macbook) using Kies Air over WiFi but it seems really intermittent. After a few seconds of idle, when the phone screen turns off, the browser on the Mac will say that the server http://192.168.0.xxx:8080/ is not available... and if I refresh, it does not reconnect. My browser will suggest restarting the server, so I turn Kies off and on on the SII, but still no luck. Then after a few tries it will connect - sometimes have to use a different browser (Safari instead of Firefox) or clear the browser cache but sometimes even this doesn't work. It just doesn't seem dependable. :(
Is this common behavior? Any tips? My WiFi signal strength on the phone is not the greatest, often just 1 or 2 bars. Could this be the issue?
Thanks!
Sn1per 117
Flashaholic
Jan 29, 2012
232
33
The wifi strength could be a problem. Kies Air has a good idea, but the functionality just really isn't that great. Even when I have full wifi on both my laptop and phone it is still incredibly slow/laggy so I haven't really used it much. IMO it's a lot easier and more efficient to just plug the phone in with the usb cable and mount your phone to transfer files.
Sent from my SPH-D710 using Tapatalk 2
Reactions: vidroid
DEF3NDER
526
129
I had a similar experience with kies and I hate it. I use Airdroid all the time. It is better than kies in every way.
Sent from my SPH-D710 using Android Central Forums
Reactions: vidroid
vidroid
Active member
Jun 1, 2012
31
Thanks for the feedback guys, I'll try using it when the WiFi signal is better and check out Airdroid.
txpfjqmvae
