Kool-Aid--2.1--new leak!!!
Yeah I already signed on as root on the Linux Box. I will keep working with it and see what I can figure out. Thanks
Try not running as root til your in the tools folder then run as root it happens to me, i run box to it a pain sometimes.
No still no go not sure what is going on. It is not a huge deal. I just wanted to try and remove the sprint Tv.
for Unix based devices you have to type ./adb, are you doing that?
from your first post it seems you also need to type sudo beforehand to login as superuser...
Hey Beezy how difficult would it be to get a PRI that supports wired tether into the Koolaid? My PRI is stuck on Flipz_1 so Wireed tether of course no worky.
A pain ive messed with it before to see what i could do,Ill see if i can get lucky i highly doubt it,but worth a shot.Easy tether is pretty good if you get paid version it really nice i use it when my neighbor shut off wifi.lol
I'll give easy tether a look. thanks.
Gunnyman, I've answered this tons of times over at XDA but not so much here. All you need to do is to nandroid backup your current rom, install Damages V1.1 beta 5 (Google for it). It will change the PRI to 2.11. You will lose "Sprint" in the lockscreen and some Sprint specific apps won't work (Nascar NFL etc.) but TV and Sprint Nav will work. Then just nandroid restore this (or any other saved rom) the PRI will remain unchanged. USB tether works great with this (and every other 2.1 rom) I use it often at airports.
I've installed the Sugar Free Kool Aid and everything has been great so far except....
whenever I try to go to "Manage Applications" I get a force close. This happened to me on the Option 4 ROM as well. Does this happen to anyone else? Any ideas?
Settings > Applications > Manage Applications = Force Close :(
I haven't had it happen to me on either of them but ive had it happen to me before.Does it happen everytime and do you know if it happens before you install any apps or not?
Yes I am using the ./adb devices. I am Already logged in as Sudo or Root on the machine. I have tried not logging in as Root until I have been in the directory, prior to getting to the directory, and have even tired re-installing the whole Android SDK. I have rebooted the phone and the computer to no avail.
I have also used nandroid and re-installed 2.1 option 3 and it seems to be fine in the previous version. I have just removed the packages from Kool-Aid-Suger_free.zip that I did not want and re-installed. I can still not use ./adb devices to log into the device. Not sure why, but am also not really worried about it. I did want to take some screen shots, but am not too worried about it.
Thanks for the help so far.
Wow, thanks for the quick reply!
It's happened everytime I've tried, although I've only tried after I've reinstalled my apps from Astro. I'll wipe and reflash to start over and try again before reinstalling any apps.
Exactly what happened to me. Before installing apps it works fine. Twice I used Astrology to reinstall some apps. Twice its broken I think that's it. This time use the market.
Sent from my HERO200 using Tapatalk
Shoot Me from the market takes screen shots,thats how i took mine that are on first post.
Pinch to zoom does not work.
Also, the calculator isn't...calculating...correctly. Any number divided by 9 gets a wrong answer. For example, 350/9 shows the answer being 8.888888888. 35/9 shows .8888888888. 15/9 shows .6666666666.
Any clue as to why?
Any clue as to why?
Not really,i think your calculator has been drinking.j/k Both work for me.Anyone else have this?
*Edit can you pinch to zoom on home screen?
mmn112233445566111
