Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
Since we're on the subject, whats the difference between the bekit kernals? (5 slot vs 7 slot) It is my understanding that the low voltage ones use less heat. If I was to install one of these kernals, would it eliminate the need for using an overclock app?
No you still need setcpu. But the difference is the available frequencies to set your phone to
Try and wipe data . But first click fix permissions and reboot see if that helps
If moving from .4 to .7, wipe data and clear defaults in launcher 2.
Setting, manage apps, hit menu, filter, all, find launcher 2, clear data and defaults. All you will have to do is reset up the home screen.
I'm running Koush's rom version .7 and just loaded p3droids 1ghz kernal .. Man, this thing rocks. I have never been able to run over 800 mhz with bekits kernals and it runs hot @800 but with p3 I am running 1ghz stable and cool. All while streaming pandora and usb tethering .. lol
How do I get out of the endless FC loop with the .7 update?
The Launcher 2 one. I have no idea how to get my phone working right now just FC's all the time.
Pull your battery then turn back on holding down the X key to go into recovery then restore from your back up.
Nevermind I deleted it. But in launcher 1 is there anyway to get the icons across the bottom again on all pages?
You need to download helix launcher. There a thread that had the installation apk in the apps section.
I installed CM .7, and everything has been good. But, I have just noticed that I cannot enable wi-fi. I can't say that wi-fi worked with it any time, but I think that it worked to start when I first installed .7. Just to check, I went back and installed CM .4, and the wi-fi started working again. Any suggestions?
The message that I get is "unable to start wi-fi".
contactbrii14017
