Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
i dont have apps2sd enabled but i cant figure out why it's not working i fixed permissions and i rebooted but didnt work.
Is it just me but every time I touch the screen to play with my live wallpaper my led notification lights up red
I can find it in astro but it wont let me install. Its not the helix launcher that was posted. Its a new one that DA sent me.
Oh that could be the issue I'm talking about the wrong one just disregard everything I said then
haha its all good. but bizz you should be able to help me with this. which kernals should i install, the bekit or the p3droid one? i dont know if there is a difference or not?
I hear a lot of people going with the bekit one. It's very stable.
However, this might be blasphemous to say, but i'd try and go without overclocking for awhile. I found that CM, above any other ROM, was fast even without overclocking.
Yup, bekit is what I also use. Bit, I sent you an update zip. Shay d installed it with the update zip and it worked. LMK
I have the launcher working but I just can't get the new one with the Droid icon that opens his mouth when you put something in the trash bin. I installed the 2nd file you sent me which is the helix launcher itself with the 3d app draw icon the right side butt can't figure out the other part.
I am on stock 2.1 now. I was wondering if the battery life is any better (or worse) on CM 7?
Also, if I decide to go with CM, I have to go back to 2.0.1, then root my phone, then install ROM manager, and install CM 7. Is that correct?
TIA!
Battery wise I'm not sure but I think its probably better on CM. And your right with the steps you have to take to root since your coming from 2.1
For me, the p3droid kernel run a lot smoother and colder than the bkit ones.
Bekit at 800mhz would run around 35?-38? and the p3droid 900mhz runs at around 30?-34? or so. Huge difference to me!
Ahh well it works for me, so when running koush's rom I use his kernels. You know what runs hot? stock 2.0.1
I'm running it at 550mhz (stock) using the stock kernel, and it's running at around 37? C almost all the time. And 600mhz? Pshh thats ~40?
If I download the p3droid kernal after I downloaded the the bekit one, do i install over it or do I have uninstall the bekit first
No just install over won't. Hurt you can reboot into recovery and format boot then flash the new one
after updating to .7 i have found somthing that i have been missing ever since i originally installed Koush's rom. here is a hint.......
DROOOIDDDDD!!!!
that made my day when i first heard it. i love that notification sound.
masonbiz5
