Lag problem
Franzferdinan51
152
3
18
Okay so I have had this phone a couple weeks and I'm noticing lag I have advanced task killer and memory booster lite I was wondering how do I fix my lag I'm on a stock rom I got right here on android central with xionia oc kernel over clocked too 768
Sent from my VM670 using Tapatalk
I always clear my cache n app2sd then reboot my phone then kill apps after startup.... On ur task killer how much ram does it say is free after killin apps? My phone says 337m free
Says 308 and I have already put all apps on sd is their anything else I can do
I know that you are typing from the VM670, but please user proper grammar.
Example:
Killing
Your
And
and please use the comma
You dont want others to misunderstand you.
-teki
Example:
Killing
Your
And
-teki
Nobody asked u... Ppl want help and im helpin.. I have a 4 month old n my hands over half the time im typing so fu?k off
Corrections:
You
People
Helping
in
I am
I personally would not want to be your child with all that language and smack talk! :eek:
i used task killer till i stopped to think "this is not windows.." u dont need something to kill task u can do it urself .. i got a lot less lag when i removed task killer .. try it maybe its just me...
Corrections:
[snip]
Quit wasting forum space with your English lectures. We understood him and since no one else called him out on it, perhaps you should just learn to live with it.
As for lag, I'm not experiencing any lag except for the initial loading. Note that I don't use apps2sd, nor have I clear the cache... not yet, anyway. Phone works fine here. It's overclocked as well.
jenleasch12683
