Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
I am now in Android System Recovery <2e> blue
I used the d101 recovery. Where do I get the d101 package for install. Sorry about the confusion, but I am stressed right now. I just want to make sure that I do it right. I downloaded a d101 .tar package. Do I put it on the SD card?
I'm stuck in the same screen, cant get the download mode so i can use odin to install CWR
changed the port, nothing
hold down up/down keys+power. nothing
all i get is the android system recovery <2e>
you're pretty much stuck until they get the market issues straight.
Searched web for apk, mounted SD and copied apk, file installed and runnined restore
reinstalling all old apps from backup good to go hope this helps anyone else having same issue
Has anyone else noticed that the samsung keyboard does graffiti handwriting input? I thought that was a nice touch.
FYI: The market will start out as the old market and then it will update itself.
And the fact you can't download appbrain is probably not related to cache, CWR, or what method you used to update to Froyo.
Anyway here it is.
Reactions: ThanosOfTitan
I recycled my phone just now and I now see the new Market. Keep in mind I have rebooted/recycled/batt pulled MANY times today (at least a dozen) and I am just seeing it now.
Do you need red cwm or is green ok? I removed voodoo with red and installed a non-voodoo kernel so red is gone now. Does DL30 break the old green?
Anyway here it is.
Yeah... nothing is downloading properly. As this link shows it seems to be broader Android Market problems.
any apps ive downloaded today 2/1/11 wont download. ive never had this problem before. incredible by htc - Android Market Help
And Android Market usually updated for me in like 10-20 min. I have been on this Froyo Leak for 6-8 hours. Oh well just wait and see... no worries. All things in time!!!
Tried two different restores..and it's just hanging on the samsung logo. Does this mean I lost everything on my phone, pictures/texts/ect..? I also did a titanium backup before I tried installing froyo. HELP!!!!
forgot the Fascinate already has a file manager and apk installer
Status
aaronr
