Allright guys I got my phone on my desktop, now in odin I have 2 Coms. 0: com6, 1: com3 ??
If you unplug do they both go away?
So is red CWM working as it is supposed to? Seems like some are having issues and JT posted something about a test green:
Per JT on XDA:
"Be careful using that recovery, since it still uses koush's (BROKEN ASS) recovery.
I will try to put together a usable package tonight that uses the red cwm instead. That was a mear proof of concept test, not really meant for distribution."
I removed red but installing a non-voodoo kernel.
Having the same issue. Has anyone found a solution to the "Message too long" error?Anyone having issues with emails not displaying. "Unable to load message. Message too long"
Alright, Im completely stocked DL09. Now do I start from number 1 again. What can I do to make sure I dont get force close again.
Yes.
As a change to step 1, instead of trying to race the phone to get your battery out, just flash with Odin with it already removed. The computer will power the phone via USB when it's in download mode. That way, when Odin finished flashing, it will just turn off.
Per JT on XDA:
I removed red by installing a non-voodoo kernel.
