Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
not sure if this has been posted but I read through the first 25 or so pages and didn't see it and it's not in the second post (also it's 1a and I'm too lazy to sift more) but I just noticed that I can also now set ringtones per-contact for google-synced contacts, not just phone contacts. not sure if it works for other contact services or wahtever but yay! finally!
Reactions: sjenkins1009
I haven't noticed any issues. What exactly is happening when you're trying to play a video?
It says that flash player needs to be updated. So I click the link and it takes you into the market to download to flash player 10.1. Installed..and still says it needs to update when trying to play videos. Tried reinstalling the adobe update, with same outcome. Even restarted the phone..
I downloaded 7-zip and it worked and I used the odin and it worked with the clockwork red and i followed the instructions so now I'm about to hold down the buttons and see if it is red!!
Awesome bro congrats
hit the thank you button for chris he deserves it
Hmmm...try clearing the apps cache. Settings > Applications > Manage Applications > Adobe Flash Player > Clear data/Clear cache (if there is any)
OK so now what is voodoo and the lag fix, Should I do anything other than choose the one that says install zip from sd card or what!! do I need to do a full wipe before I install, I saw some saying wipe cache and data, what about my apps will I lose em, I have password keeper, will I lose that.....
yeah you will, best thing to do is to reboot and do a titanium backup
Yeah, this was my first impulse. I went to it and there was no cache or data to clear.. I'm stumped for now lol
Awesome!! I'm glad that worked. And don't worry about the thanks, I'm too humble for it anyway ;)
Keep us updated on how things go from here.
well I already did about 20 minutes ago cuz I knew we would figure it out and I didn't want to forget to do it... I have been following this site since the incredible came out and never had to register, just read all the post and learned but I do thank all of you!!!
No problem, if the situation was reversed you would do the same for us...
we are a rather tenacious bunch.
Figured out the problem.. Plug-ins were turned off by default.
Pull up browser>Menu soft key>More>Settings>Enable plug-ins
Reactions: DroidXcon
Status
MatthewD
