Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
Finally Upgraded to Froyo
Many thanks to those that helped. It took a while but I finally landed Froyo this morning.
This site is a wealth of knowledge...
Angel
I'm not going to go through over 100 pages of posts, so I'll just ask - Is there a Mac-compatible option for the flash?
Only if you already have CWM Recovery flashed on your phone. From there you can download and copy the new_cwm.zip and DL30.zip to your sd card. Boot into CWM, install the new cwm.zip, reboot recovery, apply update.zip to get back to CWM, and install DL30.zip.
EDIT: Added links.
@Cory. I sent you a PM with my steps for you to try.
Yes. I followed your first post instruction to the letter. The first time I did it, I got Force Close Error so I went back to installing DL09 then rooting and installing Froyo. I also did factory reset before installing DL30.
you do not need to root after DL09 ..... from clockwork, wipe data/factory rest
wipe cache partition
go to advanced , then wipe dalvik cache
choose from sdcard apply new cwm.zip
after its done
apply sdcard:update.zip
then apply DL30
after its done
then apply DL30
Would I have to start from the beginning? I flashed my fascinate DL09 with Odin. Is that how I should be doing it or just install the rom manager and follow your instruction above?
are you able to boot into green recovery right now?
Congrats X. You just got the #1GB post!
Guess I'll shoot for #2GB since this thread isn't dying anytime soon. 1000+ in 48 hours?!?!
Then you're good to go. Just copy the new cwm and dl30 zips to your sd card, boot into cwm, install new cwm, reboot recovery, install dl30.
cwm would be CWMRecovery_DJ05_DL09_RED.tar.md5? if I do the steps Killahamsammich listed, I'll lose everything thing, right?
Download and put this on your SD card
NEW CLOCKWORK DOWNLOAD
after its on your sd card , boot into green clockwork, and flash it the way you flashed DL30
then select apply sdcard:update.zip
then wipe data/cache
then flash DL30 again
yes this will wipe the phone and reapply DL30 , hopefully working without error
im confused lol
i thought you hit post 1000
But you hit 1024 :p
Doing EXACTLY as I said won't erase anything, but you should at least wipe cache partition before installing DL30.zip. If you want to go from a fresh start, wipe data also.
Yeah we even exceeded this thread @534 posts, which is pretty amazing considering how many issues that update had when it went out OTA. We have a little ways to go in page views though since that one is at 102,459 haha
Maybe I'm missing something, but after flashing the new ROM I don't see any bookmarks in the default browser. I can add new ones, but there isn't an option for viewing them. I don't have the menu option to see the "bookmarks, most visited, history" page like I had before. Anyone having this? Am I just not looking in the right place.
Next to the address bar is the default browser is a Square with a Star in it. Click on that and it will take you to the bookmarks. I don't see a menu item to get to the bookmarks.
Hope this helps!
Reactions: Xplode22
OK, do I install this the same way as the DL 30?
Well, I just did it, so lets see if I broke something.
IT WORKED!!!!! YOU ARE THE MAN!!!! IF I COULD KISS YOU I WOULD!!! :D:D:D:D:D:D:D:D:D:D:):):):):):):):):):)
Glad it worked for you. No need for a kiss, unless you are a cute female. O:-)
If you want the new green cwm here is the link
http://dl.dropbox.com/u/11670464/new_cwm.zip
save this to the same place you saved the dl30.zip and flash them both one right after the other during the same recovery session. That's how I did it and have had no problems since. I have flashed two versions of Adrynalyne's super clean and the accompanying patches flawlessly through the new green cwm.
So we are using this link and we pass in odin, step 19---- we get blue and a fail in tne update zip... what are we doing wrong????
Status
off8485
