Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
this is great
i just did the mod my phone was one that force closed all the time but thanks to your instructions i got it fixed thanks for you providing the build.
I did most of the above and the Fascinate worked fine, (I didn't do a Factory Reset before the procedure).
Still all worked well with the exception of Email. It would not find the Emails.
So, I called Verizon Wireless and they had me do a Factory Reset. However, when it booted back up, the Cell Phone in an Adroid Voice told me that it could not find the Partition.
I was using Odin3.v1 to Reset the Partition, but during this Time was handed off to a Samsung representative who advised me to unplug the Cell Phone and after doing Volume Down, Volume Up, Power On got a picture depicting a Cell Phone talking to a Computer... but that is as far it got.
He advised me to take it to Verizon Wireless and have them Flash my Phone. What do you suggest?
Anyone else notice that when you take a picture, it now shows the location where you took the picture at? New feature of the camera firmware possibly? I haven't been able to find an option to enable/disable this yet.
Go ino settins hit wrench and disable gps
Sent from my SCH-I500 using Tapatalk
did you try reflashing with odin,,,, can you get into download mode, remove the battery , plug in , hold the vol down key for 5 to 10 seconds, and then the big yellow triangle pops up
if that did not work,un plug, try holding the vol down key , then plugging your phone in again while still holding vol down
if that did not work , try both of those step with battery in the phone. also try different USB ports
you need to kind of jumpstart the phone with the right voltage,,,,,if you can not get into download mode then yeah let them replace your phone
in the future you should try not to pull unplug during an odin flash.
please make sure you are using the ports in the back of the computer aswell
Ok, that was incredibly easy! To anyone who is on the fence, just follow the direction and it goes very smoothly. The hardest part was making my finger hit that "reset" button to wipe the phone before I did it. Now I just need to get everything reinstalled on my phone
Okay everyone - post #1 (red) has been updated. Post #6 (green) has been tested on one of my spare Fascinates, and worked fine. Apparently people like green better, so pick your poison.
Nice work Cory,,,, i think the other resistance to red is that alot of people arlready had green installed
I noticed when installing Red it mentions "lagfix" something or another. Does this mean I now have the lagfix installed? If so how do I uninstall if need be?
go into volume under settings and turn down System Volume. Or you can turn off audible selection and tones if you don't care about tones in the dialer
Thanks. Found that finally. I liked the dial tones, but I would get rid of them to get rid of the keyboard tones
The new, new clockworkmod recovery
DIRECT DOWNLOAD HERE
jt1134 From XDA developers says:
"So the current iterations of cwm seem to have trouble working reliably with the newer froyo ROMs, and koush's recovery (although seeming to work correctly) is quite broken. So......
please find below a new recovery package that should work for any ROM for the fascinate, mesmerize, or showcase.
This recovery is used via fakeflash, ie: it flashes a stock 2e recovery that uses test-keys, allowing you to flash test-key signed update.zips. After installing the recovery, flash update.zip from the stock recovery to get to cwm. The recovery is red, just like the voodoo versions of cwm, but it WILL NOT work with a voodoo installation (yet).
cwm_froyo.zip can be flashed via any cwm recovery, and will place the new update.zip on sdcard for you.
if you are using odin or heimdall, then use the cwm_froyo-odin package. Unzip it, place update.zip on /sdcard, and flash cwm_froyo.tar via odin or heimdall."
Original posting HERE
Thank you Kevin Gossett
Status
HourFromNow
