trucksmoveamerica#AC
Trusted Member
- Jul 20, 2010
- 8,895
- 1,886
- 113
So does anyone think there will be shortages on the note 20 series due to the virus stuff? I know you can't buy the S20 ultra or s20+ in the 512 version right now.
I would think Samsung is prepared from s20 series but anything possible.So does anyone think there will be shortages on the note 20 series due to the virus stuff? I know you can't buy the S20 ultra or s20+ in the 512 version right now.
I don't think there will be shortages unless they underestimate how many Ultras will sell like they did with the S20 Ultra.So does anyone think there will be shortages on the note 20 series due to the virus stuff? I know you can't buy the S20 ultra or s20+ in the 512 version right now.
Yeah somebody posted it elsewhere in the forums. Are you buying?
This won't be hard since there 2 and other is not looking good .I don't think there will be shortages unless they underestimate how many Ultras will sell like they did with the S20 Ultra.
I usually get the 512, and the 512 versions are usually the ones with the shortages.This won't be hard since there 2 and other is not looking good .
That's true , hopefully this time around it won't be like that .I usually get the 512, and the 512 versions are usually the ones with the shortages.
I believe the base version going to be 256 GB which is plenty and I'm going to stick to base model this time around if it's 256 GB.That's true , hopefully this time around it won't be like that .
Thats my plan tooI believe the base version going to be 256 GB which is plenty and I'm going to stick to base model this time around if it's 256 GB.
I'm thinking about doing that also because I think that's going to be the highest number produced at releaseThats my plan too
Thats what my Note 10+ is 256 and never used it up , im going for same .I believe the base version going to be 256 GB which is plenty and I'm going to stick to base model this time around if it's 256 GB.
If you order at release there should be availability for either. I just hope they don't limit color availability in a specific sizeI'm thinking about doing that also because I think that's going to be the highest number produced at release
Probably will beIf you order at release there should be availability for either. I just hope they don't limit color availability in a specific size
Bronze for meWhat color you are all going to get? I think I'll go with the new fancy bronze color. Though white also looks appealing since it's been a while since I got a white colored phone.
I'm ordering unlocked from SamsungI am very curious to the ration of 128 and 512 S20U devices in the US. I almost didn't get my 512 because Verizon changed my price by 1 cent between pre-order and actual charge to my card. Caused a huge order snafu as my pre authorized amount was off. By the time they figured it out, the 512 was already on backorder.
Thinking white this time.What color you are all going to get? I think I'll go with the new fancy bronze color. Though white also looks appealing since it's been a while since I got a white colored phone.
Why all the fuss about color? So you can look at it once a month when you remove your case to clean out the lint?If you order at release there should be availability for either. I just hope they don't limit color availability in a specific size
