Let's see those home screens!
How do you get those lockers from the xda website on the phone?
First purchase widgetlocker. Once you do then click on the lockscreen you want to download. Once complete open it from status bar and it will give you the option to open with widgetlocker or rom manager if rooted. Select widgetlocker and then select install. You can now go to widgetlocker and when you select to add a slider, it will be on the list of ones to choose. Let me know if you have any other questions :-)
It worked! thanks Saenz. I would like to make my lock screen like yours. Would you mine telling me how you got that black wallpaper for your lockscreen? and how you set up location time and weather? Thanks again!
No problem :-) yeah sure here is the wallpaper below. On widgetlocker settings go to look& feel. Then choose the wallpaper. After that choose the background tint and darken it as you like.
The weather and time i got from fancy widgets(paid app) the time is called digital one. Its a clock theme. That you download from the app itself and choose 4x1 widget and resize it so it fits centered.
Weather skin is called, simpleton white and it can be downloaded from fancy widgets as well. Select 1x1 widget and resize so its centered.
The location and temperature in words is an app called minimalistic text (free) its an awesome app with tons of ways to customize. It can be confusing to learn cause it has so much things to customize lol but just mess with it. I can help you with it if you need.
I seem to be having trouble downloading the wallpaper to my phone but the rest seems easy to do. I have beautiful widgets so it won't look quite like yours lol but it will do :)
I'm pretty sure he's using an app called widget locker by teslacoil software for 2.99 in the market
sent from my Droid X, which also eats iPhones.
I would have guessed that one wrong. Was going to guess they had taken a screen shot and used said screen shot as the lock screen.
Yup when you click on the wallpaper to the top left of your screen. It allows you to download the picture. I may be wrong.
It does I click save and saves to gallery but when go to gallery it shows a little error symbol.
Blackout
iZtTP
Lock Screen
iZm4x
Would you mind giving some details on what you used to do this? I like the black theme you've setup.
Thanks.
Sent from my SPH-D710 using Tapatalk
ADW Launcher with Shadow Dock Theme. Wallpaper is from BBT Black theme. Clock is Clockr Evolution.
This is a tad off topic since it's not yet my lockscreen, but I'm going to be working on getting together a lockscreen similar to the picture below. I really like the TouchWiz notification sliders, so this would be a nice mix between the stock lockscreen and the more feature laden Widget Locker. I'll post something once I have it together.
Thought I would join in the fun. This is what I've settled on for now... I'm sure it will change.
Every time I press home and off button A task manager pops up. It snaps pic with that. How do you screen shot without task Manager?
Taylor Bag
