Let's see those home screens!
Thanks. Got it.
First smart phone. I used to have a Nextel flip dumb phone. This thing so far is awesome. Although slightly less signal. 5 bars with old flip. Only 1-3 with this
Here's my current setup:
Lockscreen: Widget Locker with invisible slider, BobClock, Circle Battery and Missed It!
Homescreen: ADWLauncher EX, WP Clock Full, Battery Indicator Pro and WeatherBug Elite
Nice! How did you get missed it to have the number before the missed calls? Also how did you change it to say missed? Mine just says calls. I know its a small detail but i want it like that lol
Thanks!
To say missed calls, just go into monitored elements in the Missed It! app, select calls/messages/whatever else it is monitoring and select the one you want to change. You can make it say anything you want it to. To make it have number instead of words, go to output format and uncheck show numbers as text.
Reactions: SAENZ_SCENE
Missed it! is pretty awesome. I love apps that let you take full control over the output. You could literally put swear words as the descriptions for missed calls, texts and emails. Minimalistic Text is similar in that way too. The amount of things you can do with that app is staggering.
My latest ...
Glass / Reflection Theme
Go Launcher EX with Glass Theme
Advanced Clock Widget
Fancy Widgets Weather
skyo12 how did you remove the text from under the icons or do you know how to remove the black backgroung surrounding the text?
Taylor Bag
