LG G3 Why omit these simple things?
Re: Why omit these simple things?
Agreed, the USB 3.0 omission is pretty lame. I am not aware of any reason or limitation they had to not include the newest standard.
If its like the S5, many users couldn't use it anyways because of the way its implemented. Its also not faster enough in this implementation to be worth the cost in space in the phone and materials.
I'm not sure if Nexus Torch will work for you, Bungle, as I only have a Nexus 5 to test it on. It's lighweight and ad-free and just toggles via an icon. You might not have spotted it on Play Store because it doesn't necessarily pop up with a search on 'flashlight' (Aussies are like Brits and, evidently, Chinese in that we call it a 'torch').
I just installed it Nexus Torsh- G3 on TMO. Just what I needed. No ads and simple interface. THere are 2 with the same name. I chose the one with recent development.
I wonder what goes through carrier mind when they do that? To separate themselves by taking things away?
So what's a good flash light app without ads and bloat? I just downloaded super bright led. And it launches a switch with an ad. I just want a click on widget.
Sent from my LG-D850 using AC Forums mobile app
Flashlight by Zerone Mobile Inc. No adds, no data mining. Simple on/off.
Posted via my Nexus 5 via the Android Central App
I'm using nexus torch as well. It's great.
I used a tiny (182KB) no frills flashlight script widget on Nexus 4, "Nexus Flashlight Widget" by 45 Studios, and it works perfectly on the G3 also.
As far as cursor keys on keyboard, there is the new feature to easily move cursor around without leaving the keyboard or clicking in the text field by holding down the spacebar and then sliding left or right. Pretty cool.
art8090
