LG G4 - added SD card and it fails after a while with SD card removed unexpectedly.
Hi folks,
I have a one month old LG G4 that has been working perfectly.
I added a 128Gb class 10 PNY SD card and it mounted perfectly, copied over about 40Gb of data and all was well.
A while later a message popped up on the screen "SD card removed unexpectedly. It can be damaged. Always unmount SD card before removing it."
I am unable to access the SD card via the phone in any manner, if I remove the card and put it in a USB micro-SD adapter and plug it into my laptop it mounts just fine and I can access all of the data. I have run Windows check disk against the SD card an no issues were found. The phone is still unable to mount/read the card.
I went as far as to remove the partition from the SD card and reinstalled it back in the phone, it was then detected and the phone auto-formatted it, and then I was able to copy my data back onto the device... and about 10 minutes later the same error popped up "SD card unexpectedly..."
I have a second identical SD card, I tried using it and the same exact problem happened.
Any thoughts on what to do?
Thanks,
_x_
Hi folks,
Thanks,
_x_
