LG G4 The WIFi sign keeps flashing and says Turning Wifi On but doesn't. How can I get my wifi working?
  • Start date Start date
I had this same issue on my wife's AT&T LGG4. I turned off the battery saving mode, then restarted the phone and this fixed the problem. Hope this helps.
Re: LG G4 The WIFi sign keeps flashing and says Turning Wifi On but doesnt.
No update for yooouuu
I have the same exact problem.
Purchased the Hong Kong version H815T and using it in the UK.
It worked fine for 5 months but then wifi and bluetooth refused to be controlled (turned off / on).
LG is acting like they are different companies in different regions and LG G4 refuses to fix it under warranty.
LG Hong Kong is not replying to my emails.
Never again LG, not even a TV, not even a refrigerator, not even a pen!
My AT&T G4 started having the same problem 3 weeks ago. Really sucks because I've had the phone since August and was working fine then. Using a Note 3 now.
I'm even more disappointed because I don't have the receipt for it when I got it at the AT&T store, so I can't send it to LG for repair. Can't do much for now.
Have ur device updated to android m.Its available in honkong just try to update to android m guys and some one pls post abt it.Does android m solves this issue or not.
Thank you so much for this! I tried the more complicated solutions (with trepidation, because I don't know the ins and outs of some of the things I was changing) to no avail, but what always works is to turn the battery saver mode on if it's off, or off if it's on, and restart. Works *every* time.
This was supposed to be a reply to #41, but it didn't nest there, so I've clarified :)
I tried battery saver on or off n restart but it aint working for me.
Any 1 with this problem updated to android m?? Any1?
Hello,
my phone (LG G4 H818P) also had the Wifi flashing issue and I returned it today (eBay trader from Hong Kong, I am from Germany. I will get a replacement or money back as soon as the phone arrives).
I did the mistake to not write the serial number down, could you guys do that if your phone has the issue? Maybe it is from a certain batch or something
I am having the same problem here....... will never buy LG products anymore.
I have just got my new phones for 2 months.......
Hello Guys today I faced this issue while connecting to my wifi, I restarted the device it didn't worked then I opened the back and pulled the battery out for 5 minutes when I turned my device on the WIFI was off and when I tried to turn it on again it started blinking again, after calling the LG Customer Support they said me to do little things and it's working again!
SO heres what to do
goto Settings-General Tab-Apps then clear the data of these selected items mentioned below.
1) Config Updater
2) Download Manager
3) Google Account
4) Play Service
5) Play Store
6) Framework (Well I couldn't find it on my Phone)
7) Home
8) Setup Wizard
9) Web Services
10)Settings
Clear all the data of these selected settings and I hope it will work. God Bless All of you And may God bless our Phones.
Peace.:)
This seemed to have done it for me - for about 10 seconds. I need to investigate further ...
I am on 3 in Denmark
Thanks OzzyPT - will try that next time.
Did a factory reset. Problem persisted. OzzyPT - would a factory reset blank out the file you indicate?
After the factory reset, I fixed it by pulling the microSD card and wiggling around the SIM card. Specifically I pushed it towards the center of the phone. The SIM on this model does not have an obvious way to remove it so I went with re-positioning it.. Booted it up. It worked. Put the memory card back in. Booted up. Still working. I wanted to remove and re-seat the sim because of something someone said above about lacking hardware ID's...
My phone was a T-Mobile Alcotel One Touch (3 months old)
this worked like a charm, thank you for your advice!! so simple.. i never would have thought to try that in a billion yrs!
I am having the same problem. On "3" in Denmark. Model H815 from august 2015. Returned the phone today.
I have exactly the same problem adboard LG V10 from Hong Kong and Wi-Fi Bluetooth and FM radio doesn't work also I sent email to LG in Hong Kong they didn't reply what can I do with this wait for update or change the company.
Hi i have exactly the same problem I'm living in Uk I bought LG V10 from Hong Kong dual SIM after update Wi-Fi Bluetooth and FM radio stop working I have done everything what I could but still doesn't work LG in Hong Kong doesn't reply my email and what now I can do nothing by new phone but indefinitely not from LG
I had the same issue with my LG. I cleared my cahche for
Download Manager
Config Updater
Google Play Service
and Play Store Services (kept getting play store error messages)
and the took out my battery for 5 minutes.
Hi, after using my phone perfectly without problems for about 3 months I now have the same problem and it's driving me nuts. I want to try your way of fixing the problem, but don't want to root my phone because then I'll probably lose my warranty.
What do you mean by 'you can remove it via adb'? I don't see any folder named adb in my internal storage... Can you please elaborate? (Sorry, I'm not very familiar with all this)
Thanks
byronsss
