LG V20 - Show us your homescreens!
Re: What launcher are you using?
I am using stock launcher with high contrast (-dark) theme. I forced GPU rendering in dev settings and this thing just flies.
Not so satisfied with Nova and launchers.
What did you use to make the icons
I just found a Batman icon and swapped out the center icon with a phone app called PicSay. Then I changed the overall color
Next 3D Launcher Re: What launcher are you using?
Next 3D Launcher wont work in my HTC U Play smart phone. light will off ones battery is below 30%or more. Is there anyone can guide me more about these issue i purchased 3D Launcher apps from apps store.
thanks
Re: Next 3D Launcher Re: What launcher are you using?
thanks
I'm running Next 3D, but I'm not exactly sure what problem you're describing. Could you clarify it with some more details?
Also, I wouldn't bother contacting the developer. As much as I love the launcher, customer service is zero. I'm not being figurative, either, as every attempt I've made to contact them has had no response.
My new setup for now. I'm just starting to learn how to use Zooper widgets and KWGT for customization and discovered some new methods from watching the "Best Android Setups" series on YouTube.
https://youtu.be/QpEV4aAgCc8
I'm using Nova Launcher with Plain Icon pack. I used the newly discovered KWGT widget for the battery widget. I'm still learning. Also I cannot for the life of me get any of the weather based widget to work in Zooper widgets. If you have any tips I would appreciate them. I manually entered in the high and low temp on the one I have just to replace the ?? that were there. Background made with Tint app.
brightness is 0% when battery running below 30% or more it means i cant see anything on my mobile screen.
more about that is screen running black its look like "someone switch off phone after or below 30%.
If you need more details or give me hand than let me know.
thanks
thanks
That sounds like more of an issue with your phone's settings than the launcher. I'd check your power/battery settings for a battery saver type option.
Using Smart Launcher because its the only one that seems to handle landscape the home screen layout well.
My favorite launcher... Love all you can do with it. Tried Nova since everyone talks about it... Went right back to smart. Lol
Crissy Doug
