LG Viper roms?
Re: lg viper roms?
Got it. not sur how to merge lg files(android/kernal). Any suggestions? How to compress .vdi? Hd low on space. &&? The tutorials read its the final step. Will && merge?
You should've synced the kernel to a directory inside your build environment ex (/home/nigel/android42/kernel/lge/ls840).
Re: lg viper roms?
Stop looking at tutorials, ask us for help when you get lost. Delete the files and redo the git, then recompile.
Process:
Make install
Edit the config with nano, or vi, or something
Make config
Make
The install makes the file tree
The config makes the actual make file
Then make builds the package.
Sent from my XT926 using Tapatalk 2
Re: lg viper roms?
I know. Incorrect version also. switched to nigels code for java6. switched up cache. Same results. i restarted yesterday evening and was getting unknown device at boot. uninstall reinstall, nothing. im starting from scratch. Will java6 build proper ubuntu 12?
Re: lg viper roms?
Search the universe for Java 7
(If it's still called universe)
Re: lg viper roms?
Nm java. started from scratch,got java6, got all programs, cache, rules. Got open source zvi extracted. Got toolchain. how to merge zvi folders to code?
Re: lg viper roms?
Looks like kernal info paste to manifest? Im oblivious to kernal. If thats the case, i have android+kernal zvi folders. manifest? Wtf
tota
