LG Viper roms?
Re: lg viper roms?
Hang on, ate you making a GB kernel or ICS?
Sent from my XT926 using Tapatalk 2
Re: lg viper roms?
yeah. nm. pullin' the plug on this project. thanks for the help, however i learned the method to rooting zvk. if anyone is interested in my help for testing or compiling. i have minimal exp. but the necessary tools for it. if anyone is interested my final build brought the infamous legacy tag error. and the .mk files were all optional except one. i changed it and got a new error about hard module something or other....ANYWAYS* peace for now.
Re: lg viper roms?
Thanks for the try!
Sent from my LG-LS840 using AC Forums mobile app
Re: lg viper roms?
http://pastebin.com/AGpcTc3r
Dude, I just realized the repo you posted earlier has instructions. Not even instructions I made up, instructions straight from LGE's open source website.
  1. You're using the CyanogenMod source tree, go AOSP. It clearly says it in the repo.
  2. You're building for the Sony Xperia Ion (Aoba). Just because they use the same chipset doesn't mean they have the same kernel config.
Just for clarification, I re-posted LGE's instructions:
1. Kernel Build (User) -
Unzip LS840_Kernel_ZVI.tar.gz at the android folder
When you compile the kernel source code, you have to add google original prebuilt source (Nigel Edit: USE AOSP) into the android folder.
$ . build/envsetup.sh
$ choosecombo 1 generic user - Build kernel
$ cd kernel
$ mkdir -p out
$ make cayman_sprint_us_defconfig ARCH=arm CROSS_COMPILE=arm-eabi- O=out
$ make ARCH=arm CROSS_COMPILE=arm-eabi- O=out
After Build, You Can find the build image at /out/arch/arm/boot
Ima take a shot on this, I'll put up the results.
Alright don't laugh I'm still a noob at this, but I'm getting an error when running 'repo init' here's a pastebin. http://pastebin.com/AGpcTc3r
Re: lg viper roms?
$ cd kernel
$ mkdir -p out
Dear Nicholas,
$git blah blah blah
$tar -xvfz LS840_Kernel_ZVI.tar.gz
$mv -rfv LS840_Kernel_ZVI/ ./android && cd android
Then follow the steps from there
Re: lg viper roms?
Dear Nicholas,
$git blah blah blah
nicholas@LinuxWorkstation:~$ git blah blah blah
git: 'blah' is not a git command. See 'git --help'.
Re: lg viper roms?
Dear Nicholas,
$git blah blah blah
thread wont close. anyhow, i forgot to mention if anyone is interested in devoping a jb rom specifically on my final post. also. ^ this is the information i was needing! i would have enjoyed building an ics rom. no worries, i zvk rooted/no bloatware/and a cute stock theme for now. [ROM][JB] [4.2.2] Avatar ROM for LG Spectrum (vs920) - Updated[Sep 21, 2013] - xda-developers what is the possible level of getting both spectrum+viper open source and merging content to create jb rom? ..........good luck on that ics rom pro
Re: lg viper roms?
ran lunch 1 with aosp 4.2 to test my environment succesfully. looking into kernals now. any suggestions?
Re: lg viper roms?
New questions; integrating kernal possible with locked bootloader? If so, would baseing gb work? What files should i look for specifically ? is sdk the best resource for kernel enhancement? Will 15 gb cover the entire process (50gb with aosp/env. Currently.)? If i create a github account, will i then be able to git clone the neccesary kernal sources'? Is a jelly bean a fruit?
Re: lg viper roms?
Jelly beans are gross little sugar and gelatine candies. So yes. They are fruits.
tota
