[LINK][ROM] CM7 for Thunderbolt. RC1.3 Updated 7-24-11
I have a permanent 10.2 flash apk saved to my sd card, I use supermanager app to install as needed... most aosp rom require 10.2 for work correctly...
First time I've tried CM and it's pretty sweet so far. The original post mentions audio problems. What audio problems should I be looking for?
Although I'm glad to be rid of sense, there are little things I never realized I appreciated until they were gone. For example, I miss having the option to delay my pattern lock screen separate from the slide to unlock screen.
just flashed and im on reboot now.... is the htc white screen supposed to be on for a while? ::bites nails::
**** i think i screwed up.... i flashed the gapps instead of the cm7 LMAO
im in recovery now restoring my last back up as i type this....after i flash cm7 rc1.3 how do i flash the gapps? lol i feel like a ****** ... reading:2 me:0
Yes thru recovery, just like you flash cm7, ROM manager or reboot into recovery and install .zip from sd card.
Maybe uncheck Automatic in the time settings, set it correctly, reboot and then recheck automatic? something along those lines.
Everything is actually working beautifully on this RC1.3, and I mean everything... I cant believe it... it really works :) nav, camcorder, everything :) minus video chat on Gtalk but i don't use that anyway
Do I have to do a full wipe when going from 1.2 to 1.3?
Any fix for slow gps lock yet?
AFAIK, when going from one release to another on the same ROM you can just treat it like an upgrade, but if you can swing it it's never a bad idea to just wipe and reload your apps through titanium. I'm doing the former right now, but I'm making a nandroid first.
With every update, I find myself REALLY wishing that camcorder audio has been fixed. Backup running right now, crossing my fingers!!
slayher actually said "No Data Wipe should be required, but as usual, if weird stuff happens, wipe it." You can usually get away with it on minor updates but two things...
1. Always make a nandroid backup first.
2. Never complain or post bugs or issues you are having unless you have done a full wipe and install.
Those are the rules I live by anyway. :confused:
Also, ever since I did the GPS fix the longest lock was like 10 secs, and most would be like 1-5 secs. If your having issues you may want to try it.
Reactions: ssethv
Link to gps fix?
Here you go SoDev... this is the screeny of the Minimal magic theme you wanted to see... Read the PM i sent you for more instructions :) let me know if I can help... also, it changes alot more than just some icons... it affects the way alot of things look all through out your phone.. just hit the market and search for CM themes, there are a ton of them, once you DL what you want you can select it from the theme chooser in you app drawer. you can also customize the theme too with adw ex, like changing the icon dock etc... thats why I love adw ex, well worth the money
chriiis
