List of nexus 7 2013 problems
cord is a bit short, I've had the nexus yank off the table twice so far, once it left a ding in the very soft sides....careful about the sides and bottom, almost seems like it's made out of a stiff silly putty.
has anyone had a problem with the battery symbol showing an exclamation mark? stats show 0%. i've had it since 7/27 and it's worked fine... woke up this morning and the exclamation and 0% is all i see. :(
That means your battery is dead. Does it still do it even after a charge?
Posted from my new Nexus 7
I'm not really seeing any big hardware or software issues. Smooth like buttuh! One small gripe I have is that when you are using earphones and the device goes to standby or sleep, there is a buzzing or whining sound that comes through. Perhaps it's just my device.
I hear a buzz sound from the speaker when the volume is low and playing sound. I haven't tried the headphone jack yet to see if the problem is there as well. The problem seems to go away when you turn up the volume a few clicks.
How to fix the mediaserver battery drain ive tried many methods
Sent from my Nexus 7 using AC Forums mobile app
In my experience it's been a media file (usually a photo) that is corrupt. Try deleting the last few photos you've taken.
16 hours of constant heavy use here on my 32Gb WiFi model and zero problems of any kind. I love this thing! For me Asus and Google hit it out of the park!
What!?!? George Lucas is here!!!!
Still no problems after 4 days of heavy use. Who is George Lucas?
Sent from my Nexus 7 (2013) via the Android Central App.
My 5GHz antenna keeps dropping out. I lose visibility to all 5GHz networks around me. 2.4GHz continues to work fine. Happened the past two evenings 1 time and twice tonight. Toggling airplane mode brings it back. Seems like software. Anyone else seeing anything similar?
I'm getting absolutely no sound from the speaker near the usb jack. The other speaker is fine. My local Best Buy has the 32 back in stock so I'll return this one.
As far as that bright line flash goes when you drop to sleep mode, I find it mildly annoying. Maybe they can fix that in a future update.
Anyone else having a screen flicker issue? In chrome, and pretty much anything, my screen is sporadically "blanking out" for a second (or less). Seems to be happening whether I have auto brightess on or off.
GPS also seems pretty flaky. An app called Navigator allows you to display how many satellites your locked on to, and it fluctuates wildly, whereas my Galaxy Nexus indicates a more stable number.
Screen flicker issue is definitely concerning me, but planning to wait a few days to see if this might be widespread and software related.
Yes, I'm getting the screen blink issue. Happens about once every minute or two. Seems to be Chrome and Chrome beta mainly. Can't track down why. Turned low-power WiFi off in WiFi advanced settings and still does same thing. Pretty annoying for an otherwise near perfect tablet.
How is the touch for everyone? Once and a while I find myself having to press things on the screen 2 or 3 times to get it to register. Not sure if my tablet is having a problem or if its 4.3 and certain apps. Interested to see what others are experiencing.
I haven't had an issue with touch.
Sent from my Nexus 4 using AC Forums mobile app
Just to update you guys on my situation... Still at 0℅ and no battery stats after 12 hour charging. Asked amazon for a replacement :(
This one was perfect too, no dust or dead pixels or anything wrong except for the battery connector I'm guessing
lumaplay
