live wallpapers
I havent had any issues with live wallpapers. I did have to make sure they were on the ignore list for my task killer but overall they work fine.
I did find that with using Hancent, if I use the quick reply option they will sometimes revert back to the previous static image I had before getting 2.1. It's not a big deal for me though because I don't use quick reply very often anyways so I just turned it off.
I also use Beautiful Widgets and have no problem there either.
Live wallpaper also disappears with chompSMS
Okay as I stated earlier my problem with live wallpapers is coming from handcent I just tried uninstalling it and reinstalling it but when I get a message popup and am typing a reply, the keyboard disappears when this happens the live wallpaper goes away and the old static image shows back up. Anyone else seeing this?
I have had this problem with Live Wallpapers since 2.1 was pushed out. I use the widget for CHOMPSMS and any of the default live wallpapers, but it still happens. Grrrr!
FahadsTech
