LTE Doesn't Work on my Samsung Galaxy Note 3
I believe you have a Chinese clone international model which does not have 4G LTE radios so you would not be able to access LTE service no matter what sim card you put in the phone.
Someone else may have more info but I believe this is correct from my Google search.
Sent via The Big, Bad, Beautiful Note 3
What model is the device? Carrier version or a 900/9005 model? Though 9005 models support 4G, it's international 4G and not carrier or USA compatible. The 900 has no LTE radios built in it.
Sent from my SM-N900P using Tapatalk
As said here OP you bought the 900...so no LTE radios are in the phone.. Hence why you are not getting LTE.
Sent from my T-Mobile Note 3 using AC Forums.
Be careful if you choose to buy a new one, make sure it has lte on the band(s) and that your carrier supports
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Definitely went dunce mode not seeing the link. Yeah its an international factory unlocked 900 model. That model has no LTE radios.
I have the N9005 Version too (UK) and never see the LTE or 4G sign only HSPA+ my area hasn't got 4G yet I don't think 4G has only recently started rolling out in the UK a lot of cities don't have it yet only the bigger cities, only some parts of Northern Ireland have it have you checked with your network provider if your area has it? The only other thing is I can think of is have you got mobile data switched on?
Sent from my SM-N9005 using AC Forums mobile app
Tried with Mobile Data On or Off...nothing
Post screen shots of your network screen, where you can access the apn. It's under more settings also post the about device screen shot.
Sent from my SM-N900V using Tapatalk
I think you may have actually got a replica where did you get the device from? Your missing LTE in the network mode part section here is what mine looks like...
Bought from here: http://www.amazon.co.uk/gp/product/...ag=hawk-future-21&ascsubtag=UUacUvbUpU3480896
Do you think Amazon would cheat the clients? So should I ask a refund to Amazon?
I have a strange feeling that if I change the network provider I'll have 4G...
Only EE and a couple others have started rolling out 4G in the UK, what network is it your using?
Third party on Amazon. Anyway if i'll try first with another network operator befor asking for a refund.
I'm using Meteor from Ireland. In Ireland Vodaphone, 3, and O2 also support 4G already.
Well for 4GLTE, it should say lte. Here is another screen
So you say if the option should always be there in the menu, even if there's no 4G signal available?
Maybe rooting the phone and using this app? https://forums.androidcentral.com/e...ils?id=com.cc.signalinfo&hl=en&token=qjjc0y8k,
Correct, the option should be in the menu if the phone is capable of lte, regardless of if your carrier or location has lte.
You can try that app, I doubt it would show any hidden lte radio though.
Personally if it was advertised with lte, the LTE should be accessible without root.
kctraci1
