Mate 20 pro mic problems
Loky11
3
Hi guys,
I have a mate 20 pro and recently my mic sounds muffled, a lot of people have said I sound like I'm talking with a pillow over my head and they cna barely hear me but as soon as I switch to loudspeaker they can hear me very clear. Can anyone shed any light please? I've restarted phone several times which doesn't do anything. Thanks.
Welcome to Android Central! Make sure the primary mic opening isn't blocked (e.g., clogged by lint). Also, try speakerphone -- do you still sound muffled?
Hi guys,
People can't hear me during calls, soon as I put it on loudspeaker they can hear me, I have tried to clear the mic holes out but still no change, also done factory reset but still no luck, at my wits end now, can anyone shed any light on it? Thanks.
You're bottom microphone/s is or are defective. The phone also has a top microphone which it uses for video/sound recording and also when in speaker mode. This is why you can be heard by other callers in loudspeaker mode but not when using the earpiece
You said originally that you sound muffled to other callers. Maybe the mic ports are just clogged up with grime or dust? There are 2 mics on the bottom of the phone, one at either side. Maybe worth putting something in there and trying to clear the holes. In this link you can see where they are and that you shouldn't cause any damage doing it
https://www.ifixit.com/Answers/View/526584/I+inserted+the+pin+in+the+left+bottom+microphone
Thanks guys, I've cleaned both bottom mic holes several times and still no difference, I get told it's like I'm talking with a pillow over my head, I've tried in safe mode and same, looks like a repair under warrenty is in order.
