"Messaging is sending a large amount of messages...."
I just ran into this problem, it is the stupidest thing I have ever seen.
This is a major usability flaw and should be removed immediately.
"One way to stop rogue apps" is a terrible excuse - here's an idea... DON'T INSTALL SH@% APPS ON YOUR PHONE.
Thought I would add my thoughts.
This is the most annoying thing ever. I used to use Airdroid or now SnapPea, but even if I send one message through either of them, I have to unlock my phone and allow it. Useless.
Does the above programme fix this issue?
Never mind. I found a solution. This worked for me on my Nexus 4 running the Latest CM10.1 nightly.
Re: "Messaging is sending a large amount of messages...."
how to remove it?
I think it either 30 or 50 messages.
it is very verrry verry annoying. It asks on every singke message !!!
i just updates to JB and hate this now .
all was working great but this is totally a turn off.
You can try using SMS Limit Unlock (download it from Google Play), it claims it can remove this notification once and for all for almost all Android version (including 4.2.2 and 4.3). You will need root, of course.
My ROM comes without that notification but I have a friend who tried it and it worked for him, so you should at least try it.
i have the same problem with my android phone... arc mobile memo.... similar with other models as well except samsung and zte models
I changed my settings and it took care of it ! Go into setting and click on security, then click on SMS message limit & you can change it there. Good luck. Let me know how it went.
uhm... hey guys. try going to Settings --> Security--> Miscellaneous and change SMS limit ... that worked for me . I hope it works for you.
Try to look under settings --> Security --> App Security
I have it there and have set it successfully to 500.
On my Alcatel One Touch Fierce XL, the max you can set it at is 200. It was set at only 30 messages every 15 minutes so thank you so much for your help!!!:)
I've noticed on my Nexus 4 if I send quite a few SMS in a short space of time I get a "Messaging is sending a large amount of messages" warning with a prompt to Allow or Deny for every message I send for about an hour after it's quite annoying.
It's not a massive issue I know but does anybody know a way to disable it? I'm hoping it doesn't involve Root as I'm bored of that scene now.
Ok l like
I have same issue with my lg optimus f5 p-875 it asks again and again and again this error ("large number of sms messages do you want to allow this app to continue sending messages")
How should i fix it reply me as soon as possible please i'm so frustrated about this thing
Changing this setting to "none" worked for me... When trying to send larger group messages I have my phone set to send individual messages (SMS) instead of an MMS. In turn, my security settings thought something fishy was going on, and the message limitation security feature was intercepting.
techveer
