Micro SD keeps unmounting itself
Meanwhile, the SD card has been challenged quite a bit, I did several backups including some with Titanium Backup. TB used to provoke unmounting of the SD card VERY often. Runs now without complaints. So there seems to be a hardware issue as the root of the unmounting problem. I wonder how long the fix will work.
Hello guys! Got the same problem here.. Also, a few weeks ago the LG G3 was having a problem to read the SIM card.. I have to reset over and over again until detects the SIM.. Now the SD os unmounting too.. Does anyone found a solution yet? Im guessing this could be a hardware problem, maybe the motherboard is starting to fail on the circuits connection.. What do you think?
We both experience the same thing. I was so delighted when my relative gave me an lg g3 phone but as days pass by this annoying "SD card removed" thingy happens all the time and has appeared since. What's worse is that some apps and pictures in my SD card have gone missing and I have no idea how to recover it! (I may recover apps though, I have APKs for it) What is the problem? Is it the SD card that may be small or that it doesn't fit the port or the phone is causing it? Is there a way to prevent this?
FYI my SD card is a 16GB Sandisk microSD card.
Bitterbuthappy
