[MOD] Black Notification Area and Blue Signal Bar for Bumblebee 2.1
I just uploaded a mod with just the icons, signal bar and notification bar changed . The drop down is back to stock.
Sent from my VM670 using Tapatalk
can you make it this color from UOT honeybread icon theme?
rodykimage.php
just in case you missed my post
Just thought I'd jump in here and say that this mod should work ok with the new Bumblebee 2.3, since the files used in the mod were not changed in the update.
Reactions: citizeninsane89
Yes, this is working fine with the new update (at least for me)
Actually, I just applied it anyway, to see what would happen, and so far so good, looks like it is working................we'll see.
I thought about uploading a zip with just the signal bar for those who have a black bar already. I mean, the bar can be applied to the white bar also, but it was made to blend with the black one.
Edit:
Here it is:
http://www.mediafire.com/?g8hd4aeu96n3ppz
It might work with other ROMs since it only changes the signal bar on lge-res.apk
I do recommend it for black notification bars, on white it looks kind of weird.
does anyone know a good uot tutorial. especially for the the optimus v. I've made an attempt, but its a little overwhelming
Edit:
Here it is:
ColorSignalBar-signed.zip
Anyway to make it the cyan/blue instead of the green? Sry but I fail with UOT kitchen
This mod rocks... Im loving the status bar animations, this + BB + go launcher = pure awesomeness optimus v!
I believe you can edit the png file for the carrier bar manually to shrink it. I'll try in a bit to confirm it.
Edit: Nevermind, I thought it would be easy but I have no idea what I'm looking for. lol
I'm sure someone else knows how to do this and I thought I remembered seeing something about a how-to on here before.
Re: [MOD] Black Notification Area and Blue Signal Bar for Bumbleb
love it. if i have time i might mod it to a transparent bar
Can you post just the black task bar with the icons shown in the first two pictures. Thanks.
ummm...it's there
I meant to say the task bar like the first one but without the status bar modified. Also do you think you could put a tutorial on how you made this? Thanks.
Does this mod work with Bumblebee 2.4 as well?
Lauren12
