[MOD] Flashable buildprop edits (stock, stagefright, jit)
Just got my Optimus T and looking forward to tweaking it a little ;) Thanks Admins, Mods and Devs for this great resource.
Rooted your phone? Have a custom recovery? Waiting on those lazy bums from Team ThundeROM to produce a version for the Optimus T but still want to mod your phone (P.S. ... were waiting on you!)? No problemo .... Androidcentral has you covered.
You must be rooted and have a custom recovery. This will not work any other way. The links to information posts on how to root and how to install a custom recovery are above. Any questions or issues related to rooting or recovery should be in those threads please :)
How To Use:
1) Download the Zip of the buildprop you'd like to use.
2) Put the zip on the root of your SD card. Do not open the ZIP and do not extract the ZIP.
3) shut your phone off then put it into recovery by holding the volume down + home + Power key until you hit the recovery screen.
4) Select flash ZIP from SD card
5) Select the zip you downloaded and put on your SD card (steps 1 & 2)
6) Confirm you would like to flash the zip, reboot phone after complete
Information:
The stock zip is completely stock buildprop.
The Stagefright zip has only stagefright enabled and hw acceleration.
The Jit zip has only jit enabled.
Deluxe has, yeah you guessed it, stagefright, jit, and hw acceleration.
These edits (the deluxe) will take you from around 450ish quadrant score to around 950ish. And a linpack from 4ish to right around 7.5ish.
Im having problems everytime i go to flash a zip file it aborts the process. why is it doing that? it says something about the permissions being wrong or something.
jeffnachatilo
